C/k trunk holes?
Originally posted by Lou Van Anne View Post[ATTACH=CONFIG]57192[/ATTACH]Can anyone tell me the purpose of these three holes? Hard to see, but one each located in the recessed ribs toward the rear of the floor board. The center one has a plug, the other two are open.Last edited by 56Golden; 08-10-2016, 11:02 AM.
It is possible that they are Tooling Alignment Holes used in the Body Welding "Jig" cleverly disguised as Drain Holes, and can be used to drain water, but until then, are plugged to keep the dirt, water and exhaust out.StudeRich
Originally posted by Jeffry Cassel View Postjust measure them. you can order the correct body plug from Restoration Supply. be sure to plug them since dirt and water can get in there too
As mentioned by Studerich, these holes served more than one function. During the design and manufacturing process, engineers strategically place designated dimples, ridges, and, yes...holes...for good reason. The ridges give strength to sheet metal panels. The holes, for stamping molds, keep the metal from moving around during the stamping/draw process as the "part blank" is being exposed to tremendous forces when it is being shaped (stamped). Stamping molds use hardened steel "dowel/locator pins." Without these dowel pins, the metal blank has the potential to shift, and for the required accuracy of critical parts, could be disastrous.
Properly designed, the intent of the dowel locators can then be further utilized to align with body bolts, or located in low points to allow moisture to seep out. If you will note, even where the rubber plugs remain, they will move around a little in the hole. That will allow water to escape while keeping dirt and debris from entering. They don't always work to perfection, but, for their intent, have proven adequate.John Clary
Makes good sense, thanks.Originally posted by jclary View PostAs mentioned by Studerich, these holes served more than one function. During the design and manufacturing process, engineers strategically place designated dimples, ridges, and, yes...holes...for good reason. The ridges give strength to sheet metal panels. The holes, for stamping molds, keep the metal from moving around during the stamping/draw process as the "part blank" is being exposed to tremendous forces when it is being shaped (stamped). Stamping molds use hardened steel "dowel/locator pins." Without these dowel pins, the metal blank has the potential to shift, and for the required accuracy of critical parts, could be disastrous.
Properly designed, the intent of the dowel locators can then be further utilized to align with body bolts, or located in low points to allow moisture to seep out. If you will note, even where the rubber plugs remain, they will move around a little in the hole. That will allow water to escape while keeping dirt and debris from entering. They don't always work to perfection, but, for their intent, have proven adequate.Lou Van Anne
62 Champ
64 R2 GT Hawk
79 Avanti II
