SBC headers for a53 Champion
  • SBC headers for a53 Champion
    Does anyone know if there are off the shelf headers for a small block chevy that will clear the steering box on my 53 champion?
    You might look at the Sanderson Block Huggers..
    64 GT Hawk (K7)
    1970 Avanti (R3)
      X2 on the Sandersons. I have them on my Avanti. You won't find better without going to a custom built set.
        I'm using headers for a 2006 and earlier Chevy truck. They dump at the rear and almost follow the slant of the firewall bottom.
        Own \'53 Commander Starliner. Red w/beige top. 350 Chev/700R4. Tilt,cruise,A/C.http://i76.photobucket.com/albums/j30/Bobphyl/StudeontheBeach.jpg
          Thanks for the info guys, I'll check all of your ideas and let you know how I make out.
            Be aware that the clearances for the Avanti/Lark bodies is very different from that of the Coupe/Hardtops. The engine setback is changed from one to the other. Just because the headers will fit the Avanti, does not mean they will fit the Coupe. Don't buy blindly. BeeJay probably has the correct setup for you.
            sals54
              Why not cast iron exhaust? Rams horn have been proven time and time again to be as good as the best header under 5000 rpm. These look great too.
              Bez Auto Alchemy
              573-318-8948
              http://bezautoalchemy.com
                Beejay,
                Are you using long or short tube, is it possible for you to post a photo of it in your car?
                  I've always used corvette snug fitting log manifolds from the 60's and cut up from the flange an inch or two and rewelded it on at a different angle to clear the steering box. Works perfect. Never had any luck with snug fit tube headers required to much fabrication.
                    Using headers that are direct replacement for 2006 Chevy Truck. When installed on truck, they match stock head pipes. Natch, pipes on the Stude are custom bent.
                      Good luck, I'm going through the same thing but a 52 and a big block. I tried cast exhaust manifolds for a 70/74 BBC corvette. No luck.
                      Looks like I'll have to have them custom made, I'm thinking fenderwell type, electric cut outs and side pipes.
                      Dean.
                        Wow, that sounds like a major undertaking. Good luck with that, I bet it will look great when it's done.
                          It is only a major undertaking because I'm poor.
                          Dean.
                            The 06 chevy has a LS based vortec engine.
                            How would they fit a small block?
                              On my M series I used Camaro block huggers , But on Chevy pickup frame , the gearbox is outside frame , so I didn't have to worry about steering shaft.
                              Sorry for poor look of headers , were taken off , cleaned up and repainted after these pictures were taken !
ID:	1704388Click image for larger version
                              Randy Wilkin
                              1946 M5 Streetrod
                              Hillsboro,Ohio 45133
