I'm very new to this site but it appears that there is a lot of knowledgeable folks using it.
My story: I have a 1953 Studebaker 4 door Commander with a standard transmission and overdrive. (my first car) I just pulled it out of storage where it's been since 1974 to start a restoration on it.
I want to make sure I can get the engine running before I get started on the rest of the car. The engine is free (thank goodness) and I want to make sure I don't damage it on initial start up so I have done the following: Changed the oil and filter. Changed the Air cleaner. Remove the plugs and fogged the cylinders with fogging oil and installed new spark plugs. Tested the coil and starter relay to make sure they are in good shape. I cleaned the lubricated the distributor, cleaned and set the points, installed new cap and rotor and installed new plug wires. Took the radiator to a very good radiator shop and after repairing several of the initial leaks they found and having to close off several tubes completely they pressured it up to test and more leaks showed up. They say it is shot.
Now my 1st question: Is there an after market radiators available for this car or does anyone know where I can buy a good original?
2nd question: Is there anything else I need to do to make sure I don't damage the engine on it's initial startup after 40 years? Any advice will be greatly appreciated.
