OK, so I have done my research and found out some things.
The car definitely has a 289 in it.
It has a long shaft transmission with single driveline. Crossmember was cut only on bottom.
The rear end is a Dana 44 with 3.54 gear. Is this the original rear end?
How will this set up work for cruising the freeway? Off the line?
What car would this set up come out of?
We drove it around the block. It runs, shifts and brakes.
Both window regulators are sticking. Seems like they hit the door panel clips.
Can you explain why there are two hoses to the heater control valve and two smaller ones next to the heater core? [IMG]
[/IMG]
I thought you guys would like to see the pennies they stuck on the breather caps.
[IMG]
[/IMG]
Where there any dome lights in this car?
What type of tranny fluid is recommended , I know it says type F but many did not like that. What is the best oil and viscosity for warmer(Hot 105 today) climates.
Here is a link to all the photos if you want to see them.
[IMG]
