I've cut the trunk off the parts car body so I work it from any side. The first of many patch panels is attached, it is the right side, bottom, rear corner. The trunk is upside down leaning on the left side as pictured. I bought a 4'x8' sheet; I hope it will be enough.
This shows the old material laid over the new.
The new piece.
First patch panel
Aint it fun welding that thin sheet metal. I don't know what gauge metal Stude used but most of the time it's a lot thinner than it was when it left the factory. What gauge are you making the patch panels from?Jerry Forrester
Forrester's Chrome
Douglasville, Georgia
Jerry: I am using 18 gauge. hawk58man: thanks, you are too kind, this is literally my first patch.Last edited by fatboylust; 01-18-2015, 08:27 PM.
Fatboylust. Pick your self up a small hand held sand blaster from someone like harbor freight. It will make welding in patches like that a lot easier if the metal where you need to weld is nice and clean. Patch panel looks good.
Nate, The stiffener is/will be weld to the mount, in the original it was pressed into the mount. I won't bother to cut out the back side.
I started with a strip of 18gauge 1-3/4" wide by a foot long. I bored a hole through a 4x4 with a 1-3/16 forstner bit and cut into 2 unequal parts. I used a 13/16" deep-well socket and my bench vice to pressing the socket into the strip using the lessor portion of the drilled 4x4 to shape arc in to the strip. I trimmed the edges to the desired width/height. Once the basic shape was done I used the socket and a hammer to tune the shape. The rounded ends were formed with a hammer and steel ball bearing (about 7/8" dia) trimming the excess to achieve the round ends. Hope you're not sorry you asked; hope it helps.
Originally posted by fatboylust View PostNate, The stiffener is/will be weld to the mount, in the original it was pressed into the mount. I won't bother to cut out the back side.
