For those of you that change-out or replace your battery cable, make sure you get a cable for 6 volts if you have the 6-volt positive ground system
Reason is, when I had my 1951 Henry J (also 6-volt positive ground) a few months back, I replaced the "live" cable. Starting was laboring. Someone pointed out that my cable was for a 12-volt system. Changed to an actual 6-volt cable.
Starting/turnover was super fast in my 6-volt system.
So, the lesson is when replacing the NEGATIVE battery cable, make sure you buy the largest diameter cable otherwise smaller diameter 12 volt cable won't provide enough JUICE to get the most out of your battery.
Lastly, for info, when shopping for a battery cable, you'll find most are for 12-volts.
Reggie
Reggie
