My existing master cylinder was leaking so I decided to replace it. It was not he original one and I couldn't find one to match. It had both brake line ports on the side. I went to Avanti web sites and found that it was supposed to take one from a 1967 Ford Fairlane 500. This had one of the ports on the bottom and when I tried to install it, the bottom port was so close to the fender well, the brake line could not be connected. I cannot return it. Home reservoir needs to be larger than the other. The only one that I could find that even came close was at NAPA but the bore is 1.125 which is larger than it should be. I bought this for another $50 and hope it works. After putting the brake fluid in I won't be able to return it. Just be aware that the 67 Ford cylinder will not work on a 78 Avanti.
I haven't been able to drive it for two weeks. I hope I can get it ready for "drive your studebaker" day.
