Speedometer Pinion Gear Needed
  • Speedometer Pinion Gear Needed
    In need of a speedometer pinion gear for my 1957
    Packard wagon.
    Studebaker part number is 1541357. Believe it has 16 teeth. New or good used ok.
    Thanks all
    Lt. Col. Jimmy Doolittle
    That part number is showing up as a snap ring.
    1541357 RING
    1541327 SNAP RING
    Brad Johnson,
    '56 Sky Hawk in process
      1541357 RING
      1541327 SNAP RING
      Brad,
      Your post contains two different part numbers...
      KURTRUK
        Sorry,
        Copied and pasted that verbatim from SI web site. Yo! Ed! We got an error here!
        1557726 ADAPTER CRANKCASE VENT,1557726W ADAPTER CRANKCASE VENT,1542765 FLAPPER VALVE,533154 NO ROL LEVER,1542834 DASHPOT THROTTLE RETURN,1542353 AIR BOX GA
        Brad Johnson,
          Wow! You had me scrambling back to my 1955-58 chassis parts catalog! I wonder how many times those part numbers were transposed back when the Studebaker parts guys were using them every day. (Not you Jimmy L. Of Adams Studebaker)
            That is Chuck Collins web page and not SI.
            Robert Kapteyn
              Well what the heck is THE correct number? Then I can see if I have one.
                The 1541357 Pinion is for a 3.07 Axle Ratio and Automatic '56 B & H and '57 B, H & L. with 16 Teeth per the SP Catalog.
                I would expect a 3.31 Ratio with a Supercharger, that is a 1539348 17 Tooth.
                A 3.54 would give the heavy Car a bit of "GO" with the S/C.
                  Thanks for all the help with my car.
                  It's a 1957 Packard Clipper station wagon.
                  It has a super charged 289 with FOM transmission and
                  Twin-Traction diff.
                  So according to better minds than my own (abit fuzzy) I would need
                  1539348 pinion gear 17 tooth.
                  Is there a ID tag on the rear to ID the ratio? Nothing on build sheet other than Twin-Traction.
                    Twin-Traction diff.
                    Most critical question is, what is the rear end ratio in your wagon? According to my 55-58 parts book, if it is a 3.54, it needs 1539346, 18 teeth ; if a 3.31, 1539348, 17 teeth; if a 3.07, 1541357, 16 teeth.
                      Just back from garage. Removed tag from diff.
                      All it has is a 43 over a 13. Can anyone decipher this?
                      Ok, found a old post saying this rear ratio is 3.31 by doing the division thing.
                      So... I need speedometer pinion gear 1539348 with 17 teeth.
                        Thanks all for the great help!
                        I learned more about my wagon here and that's a good thing.
                        And I found the parts I needed as well!
                        Can't be beat!
