Thermal insulation for floor
A bit like garage door insulation from Lowes perhaps. cheers jimmijimsigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
Originally posted by studefan View PostPhillip, is there sticky peel tape on the back? And, how thick is it?
It was $12 at Home Depot: http://www.homedepot.com/p/Frost-Kin...1#.UlNEjlCsgdo
Very good. Very resourcefull. Stuff I was speaking about has bubbles on both sides and would require a bit of spray contact cement. cheers jimmijimsigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
I recently went all through the interior of my Avanti and I used Dynamat Extreme for insulation. There are many horror stories when using insulation type products for automotive use when it is not intended specifically for that. I have read of smell issues, cannot take the heat a car builds up in some floor areas and the adhesive runs and drips. You get what you pay for but I would go with an automotive specific product. The insulation has drastically cut down on the heat from the tunnel area over the transmission and it makes the car considerably quieter.
Fort Worth, TX
Originally posted by Silverplate View PostI recently went all through the interior of my Avanti and I used Dynamat Extreme for insulation. There are many horror stories when using insulation type products for automotive use when it is not intended specifically for that. I have read of smell issues, cannot take the heat a car builds up in some floor areas and the adhesive runs and drips. You get what you pay for but I would go with an automotive specific product. The insulation has drastically cut down on the heat from the tunnel area over the transmission and it makes the car considerably quieter.
But Dynamat wouldn't have been an impulse buy at HD while I was getting stuff to insulate my garage.
Lots of other automotive forums have had good luck with the stuff. I'll keep you posted on my short term as well as long term success.
DynaMat is also a sound deadener, and has some 'mass' built into it (ie: Heavy).
Sometimes the household insulation sounds crackly when you move your feet around on it.
Sometimes the carpeting feels 'mushy' with the closed cell silver Mylar stuff.
But... I have seen good results with both.
I would choose they DynaMat myself.....
Originally posted by studefan View PostMike, how thick is the Dynamat? Are there any downsides to putting in the automotive grade stuff? I am about ready to consider this for my 64 HT.HTIH (Hope The Info Helps)
I used some material called "Fat Mat" Bought it off ebay, same as dynomat, but, I got 100 sq. ft for about $125.00 free shipping. Dynomat was about the same price for 36 sq. ft. used it from the windshield lip to the top of the rear seat, including the roof, and doubled up on the floor on my 63 Avanti. BIG difference, no more hot feet! Be sure your seals to the firewall are also good.
Jim"We can't all be Heroes, Some us just need to stand on the curb and clap as they go by" Will Rogers
As of Veterans Day 2017, IHF has flown 2,450 WWII, Korean, and Vietnam Veterans to Washington DC at NO charge! to see their Memorials!
Thanks for the info Jim. I've been toying with Dynamat to help calm the road noise a bit. Fat Mat sounds like a much more cost effective option for a similar product.'63 Lark Custom, 259 v8, auto, child seat
I used the Stinger version myself. It peels and sticks just the same but cheaper then Dynamat. Its purpose is still sound damping but also has a 400 degree heat shield. I then covered everything (including the Stinger product) with basic heat insulation (about an 1/8-1/4 inch think) that I purchased from Home Depot and this stuff is the silver lining type material. End result is a super quiet cab with zero heat transfer and my AC keeps the cab cool much easier. I then laid my carpet directly over everything with no need for a backing. All and all I happy and the wife is happy!
Don't ya just love it when a plan comes together? Thanks for sharing the info about the cost saving alternatives. cheers jimmijim.sigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
