Anyone use these mounts from SI ? I had to open up the two upper bolt holes,"no biggie" I already knew that was needed. though the lower stud is a little short compared to the origonal mount,and does't take up the entire nut "I'd prefer full contact" but should be ok. but here is my real concern,after tightening the two upper bolts. as I tightened the lower nut it seemed to pull the plate mount upward just a tad "this is a Champ with automatic" towards the base of the mount.should that be in a relaxed position when tightening the lower nut ? I would have to egg shape the two upper bolt holes a little to let the mount drop some if that is the case
