Some of you might remember my tale of breaking off a bolt in Barney's rear end a couple of weeks back, whilst tightening up the bolts on the cover to fix a steady drip. Which stopped dripping, leaving my driveway clearn.
Well, last weekend I figured I'd better top off the diff lube, so filled it up and drove around... to find the pinion seal leaking nicely when I returned. (Sigh.)
So I took it to my driveline shop (in biz over 35 years and highly trustworthy) and told them I needed the pinion seal replaced, and while you're at it, let's pull the axles and pack the axle bearings. Quote: about $400.
Well, I get a call back from Jerry this afternoon. Seems there was a bit more to be done than I'd expected. Because the diff lube ran low due to the leaks fore and aft, the pinion bearings probably ran dry and feel like gravel. Gotta replace those, so need to disassemble and service. Also, found the U-joints looser and sloppier than I had thought they were, so those gotta get done as well.
They didn't get the axles out yet to check the bearings... but did find, when dismounting the rear wheels, that the tire shop who mounted my Chrysler steelies cross-threaded the wheel studs. Chewed 'em up pretty well... so those will need to get cut out and new ones mounted.
All told, my $400 job should run about a grand
On the bright side, I don't have a car payment!
bearing set 60$, oil pump 50$, well there's the parts not too bad! But then there's the crank needed turned, and it munched a rod, a full gasket set, it needed a new water pump all these parts needed shipped in too, and then the belt was bad and the plugs were fouled, and pretty soon I stopped counting so I could pretend it wasn't that expensive.
That's life though right?
