Packard V8 clutch housing?...How many do You need?
  • #61
    Jack,.....is the Packard V8 stick flywheel anything at all like the 359 straight eight stick flywheel? Also....is there a relatively good supply of V8 Packard Ultramatic converter drive plates around (auto flywheel with starter ring gear)
    Jack?....Hello Jack?
    • #62
      Thanks for those words of encouragement. And the slap in the face.
      If it wasn't a problem for me to ask my question nearly two weeks ago, why is it a problem for me to comment now? No worries though- I have my answers, and will file them away for another day. I'll go ahead and leave this thread for all those Golden Hawk owners who are beating down the door to this thread.
      Oh, wait- there aren't any.
      That'll be all I have to say 'bout that.
      Have a nice day.
      Geez it's not like Studebaker dropped a Packard engine, into a Packard specific frame, that used Packard specific rear axles, with Packard specific brakes rims, and tires....or something like that......
      You have a problem that's similar to the owner's with the Golden Hawks, that calls for a similar solution. If there's one thing about these here cars, is that parts can be made to fit each other, given enough time, money, and patience. It's all simple, mechanical, stuff!
      • #63
        Plain Brown------Not really....What Dave needs requires something much stronger than the aluminum T-U converter housing..which probably WOULD be sufficient for a passenger car stick setup. The '55-'56 Packard and Nash Hudson owners would probably prefer an automatic...so the focus ultimately became the '56J. (except, of course, for Dave, who wants to install a Packard V8 into a Bus)
        • #64
          I'll remember that sage advice when whenever we decide to incorporate our converted R1 to R2 engine and Powershift or T10 into one of our pickup projects. It's not the same problem at all!!
          • #65
            If You really feel that a pickup truck and a city/school Bus are comparable, then I think that You should go get Your glasses checked. (ASAP!)
            • #66
              Why? Did the frame dimensions get wider underneath? All buses get a Detroit Diesel instead? Bracketry made out of unicorn dust on the buses, and new ones can't be made up? Packard engine will recognize that it's in a bus and go all "Incredible Hulk" on the housing? You do know you are talking to the guy whose belief is anything can be put into anything with enough time, money, and patience, or all the work I did on the '55 was made out of paper mache' and I didn't realize it until now! If it twists it in two, and something better would be put in its place. Plus, it'd be the first that I'd hear about something like that happening, plain and simple.
              • #67
                Plain Brown.....Look, The driveline in a bus is under MUCH more strain than in a pickup truck. Consequently, every component behind that big old Packard V8 would have to be MUCH stronger if one hoped for some degree of reliability. (Are You with Me so far?) As Jack stated, (and I agree), an aluminum Twin-Ultramatic torque converter housing probably WOULD NOT be able to take the strain of moving a bus....at least not for very long!...OK?.... OVER and OUT!!!!!
                • #68
                  Well there you have it, every other Golden Hawk owner gets a torque converter housing for their Packard engines except for Dave's Packard powered bus. Dave will have to slap something together or has to go elsewhere for a torque converter, despite having an engine just like the Golden Hawk owners. Frankly though, I defer to Jack's expertise on this matter to help him out as he's worked on BIG projects such as this. Plus, if it's a unique problem, and if the aluminum version doesn't work out, calls for a unique solution...preferably from an experienced individual such as him who's played with stuff!
                  Frankly though, I still don't see the issue here....as I don't know of any other firsthand accounts of something like that happening, but this all under the assumption that all of this will occur!
                  • #69
                    Now wait a minute....I'm going about this the wrong way! Looking over the prototype box van photos for the 1955 E13, which has the same girth as that bus, it has a standard truck trans and a 2bbl 259! The difference in the gas driven, non diesel vehicles, the pickups, and the cars, was simply needing the right combination of parts. In this case, it would be the Packard engine, bellhousing, and trans, and if we're going that route, the associated engine and trans mounts to go from a passenger automobile setup, to a truck setup. It would also need a reasonable trans cooler of course, and the top speed might limit the vehicle to around 65 mph! Strain? Only if its decided that the Packard wasn't enough and we need a Cummins hanging from that bellhousing instead! Still can't see why it wouldn't work, considering Studebaker would build you anything you wanted, within reason of course!
                    • #70
                      I defer to Your knowledge of pickup trucks, heavy trucks, and busses. I always thought the greater weight of the larger vehicles, along with the heavy loads that they were built to carry, would necessitate heavier components.....Silly Me!
                      • #71
                        Generally related to this thread , here are 2 pics of adapter plates that I have .
                        These were made in order to allow a TH400 to be bolted directly to a Packard V8 .
                        It requires that a portion of the block mating surface on the TH 400 be cut off , and then this plate
                        be installed . The TH 400 flex plate(redrilled) and starter then work .
                        I bought these many years ago from the fellow in Michigan that was doing conversions.
                        He was ending his work , and these were supposedly the last 2 that he had .
                        I was wanting to go Packard in my drag car .
                        All that i have done with them is to saw off an empty TH350 case , and loosely
                        mock it up . it looked like it would work .
                        Seems much better than a spool and 2 flex plates as the Torqueflite adapter uses .
                        Posting this because it seems like a TH400 might do the job in the bus in question because
                        it handled GM and Rolls Royce Luxobarges of pretty high weights .
                        I think that a number of these are/were in use.
                        Jack Vines , please fill us in .
                        Bill H
                        Daytona Beach
                        SDC member since 1970
                        Owner of The Skeeter Hawk .
                        • #72
                          Threads like this one sometimes bring to light interesting material...material that is often forgotten about...And Bill, Your post is a good example of that. Question: Are you saying that a Packard starter or a GM starter would be used with these adapters?
                          • #73
                            I think that the GM starter is used . As you see , these are in raw condition.
                            I don't have time at this moment , but probably by Googling in the Packard world ,
                            some details may be found .
                            JV probably has the knowledge .
                            My memory dredges up the name Bill Mitchell as the man that I bought these from . That may
                            not be correct though .
                            Bill H
                            Daytona Beach
                            • #74
                              I'm off to the 'PACKARD WORLD'
                              • #75
                                If you are planning to go GM, why not install a 4L85E (16,500 GVWR rated) and get the over drive in a heavy duty unit? The TH400 (3L80 in later form) probably has a lower GVWR in stock form so if one needs a heavier duty unit than them, money will get them upgraded.
                                Bob
