What would be a FAIR price to pay for a Packard 352 (not seized) and the Ultramatic to go with it? FAIR price...
Packard Engine/Transmission Price
How complete is the engine? Carburetor? 2-bbl or 4-bbl? Intake and exhaust manifolds? Starter? Generator?
Is anything known about the Ultramatic? If not, assume it needs a rebuild and call Peter Fitch at Ultramatic Dynamics to see how much that will currently cost.BP
FWIW, rare does not always equal valuable. I'm always running across hoarders who've been planning their retirement by piling up rusty iron. They don't take into consideration 99% of used non-running Packard V8 engines will need a $3,000-$4,000 complete rebuild.
I pay $350 - $500 for 352" cores and $500 - $750 for 374" cores. It depends on how complete, how ugly, how much I need one at the time.
jack vinesLast edited by PackardV8; 07-26-2013, 09:28 AM.PackardV8
Originally posted by PackardV8 View PostFWIW, rare does not always equal valuable. I'm always running across hoarders who've been planning their retirement by piling up rusty iron. They don't take into consideration 99% of used non-running Packard V8 engines will need a $3,000-$4,000 complete rebuild.
I pay $350 - $500 for 352" cores and $500 - $750 for 374" cores. It depends on how complete, how ugly, how much I need one at the time. jack vines
I realize you are too far away to consider buying it, so I'm just wondering.BP
David Parris also has one that could be for sale in Asheville, NCHTIH (Hope The Info Helps)
Bob, the 320" is same-same as a 224" or 232"; since it costs less to build a 259" or 289", not that many to pay for the smaller engine. Most Packard guys step up to a 352" or 374". I can always use the heads, crank, rods, balance damper, timing cover, cam core and so on.PackardV8
Originally posted by PackardV8 View PostBob, the 320" is same-same as a 224" or 232"; since it costs less to build a 259" or 289", not that many to pay for the smaller engine. Most Packard guys step up to a 352" or 374". I can always use the heads, crank, rods, balance damper, timing cover, cam core and so on.
Bore diameter:
320" - 3-13/16" or 3.8125"
352" - 4.00"
374" - 4.125"
It's the same as boring a 232" (3.375") to 259" (3.5625"). The 3/16" overbore to take a 320" to 4.00" would make the cylinder walls a bit thin. Some have done it and bragged about it. I personally wouldn't want to run one, but if anyone wants to try it, I've got a box full of used 352" pistons.
jack vinesPackardV8
Originally posted by SN-60 View PostA fair price for the Ultramatic would depend on whether it is a 1955 unit (cast iron case) or a 1956 unit (aluminum case). The difference in price between cast iron / aluminum scrap metal varies greatly.
Actually, with a few more years of development it would have been a viable product. They had a direct drive lockup converter decades before the Big Three accomplished that feature reliably. Much like the Packard V8 oiling issues, a little aftermarket tweaking can iron out the known wrinkles.1996 Impala SS
1967 Jag XKE FHC
1963 Avanti R2
1963 Avanti R1
1956 Packard Patrician
1948 Jag Mk IV DHC
1909 Hupmobile Model 20
Originally posted by SN-60 View PostYou say a "LITTLE" aftermarket tweaking ???
http://www.ultramaticdynamics.com/improvements.html .
From reading Packard Forums for many years I know of many cars running this trans for thousands of miles without any issues. The 1956 version incorporated many running engineering and materials upgrades and was considered reliable by mid 50's auto trans standards. Significantly, Packard, a small independent compared to the Big Three was able to design and manufacture an advanced lock-up/direct drive auto trans in house in their waning years. It took the giant GM corporation years to work the kinks out of the early Hydramatic before it became a reliable mass produced product.
I feel most of the Ultramatic reliability issues arose from the lack of qualified service available after Packard bellied up.......it definitely does not lend itself to shade tree tinkering.1996 Impala SS
1967 Jag XKE FHC
1963 Avanti R2
1963 Avanti R1
1948 Jag Mk IV DHC
Originally posted by Packard8 View PostWell, I'm no expert on the Ultramatics but those who are seem to think they can be made to work reliably without reinventing the wheel:
DEDICATED Ultramatic fan something. I do agree with Your comment that 'shade tree' mechanics probably only made matters worse!
From reading Packard forums for many years I know that the Packard Club were the first ones to fund the designing of an adapter to mate the Packard V8 to the Chrysler Torque-flite transmission.
jack vinesPackardV8
