Any of you STUDEBAKER nuts know how to clean a fuel tank with rust in it?
Need Help with Cleaning Champion Gas Tank
aj86,
You might want to do a little www research on gas tank renewals. Restoration companies like Eastwood sell products to renew the inside of tanks - the cleaning part might be included in some.
Don't know about the small rocks (some rust might need some big rocks) but more often I have heard about people using a piece of chain to do all inside the tank work...
Good luck
Drywall screws. The black phillip tip screws available at hardware stores. A couple of bucks.
The sharp edges dig in.
Shake, rattle and roll. That gets the crusty stuff.
Acetone or a carb cleaner gets the yucky stuff. Another couple of bucks.
Maybe another round of drywall screws to make sure.
Now, this part is my idea and I don't know if it would work, I haven't tried it.
IF the tank does not have rust holes that need to be sealed.
You would want to protect the tank from further rust.
I understand that the original tanks were made from galvanized steel which protected from rust.
There are rust removers out there that both remove rust AND leave a phosphate coating that protects from rust.
They all contain phosphoric acid. OSPRO, PICKLEX, and others. 15 or 20 bucks.
Seems to me that a long soak, shake, rattle and roll with one of these would leave a protective coating.
I don't know if there would be any problem with the gas reacting to the phosphate coating ?
Has anyone tried this ?South Lompoc Studebaker
i used por-15 products on the avanti gas tank after cleaning with acetone:
was very pleased with the outcome.Kerry. SDC Member #A012596W. ENCSDC member.
'40 Champion. sold 10/11.'63 Avanti R-1384. sold 12/10.
After I drained the tank on a friend's '47, I put a handful of shale type rocks, about 1"-2" in size, then I shook and tmbled for aobut 20 minutes. Then I removed the rocks, and "poured" out about 1/2 cup of rust flakes. I then blew and vaccumed the tank good, then used POR 15 gas tank sealer kit. (It was amazing how much orangeish crud comes out during the chemical cleaning process!) Anyway, the sealer set up real nice and I am happy with the results.
Good luck
Rocks or screws are much better.
Gas Tank ReNu, period:
http://gastankrenu.com/
'No other way to go; have them do it once and it's guaranteed for as long as you own the car. You can find a dealer near you or ship it. This is not cheap but it is perfect.
1 rusty gas tank
Get about 1' of old log chain, some rocks, screws, nuts and bolts and any other small objects laying around the shop. Add some mineral spirits and seal off the tank. Attach tank to a pipe and make a way to turn it (like a hog roaster). Turn it for about two hours, drain it into a barrel and let the empty tank sit in the sun for a few hours. May want to have some sealer added to it. Had to do this to Ely when I first got him roadworthy.Chris Dresbach
