I am always trying to think outside of the box...maybe sometimes TOO far outside, but sometimes my stuff works out. So here goes my new gearing solution.
I can NOT find a 4.11:1 gear set for my Timken diff. I know I could just put in a 12 bolt....NOPE. Don't want too, as discussed in another thread.
So to help with my VERY low 5.571:1 diff ratio I was thinking of an alternative to changing the diff.
The 2R10 has a short drive shaft with a center carrier bearing. I have thought I could use a 4WD transfer case out of something like a Suburban that only has a low range gear of say 2:1 and is an electric engage on the fly style....run it BACKWARDS behind my trans {of course supported propperly and using U-joints on both sides} so that in HIGH gear it is my standard 1:1, then when I am getting on a hiway {like en route to the International??} I could put it in nuetral, flip a switch, and have the transfer case switch into what it thinks is LOW, but it would be splitting it UP. I could then probably shift the trans into 2nd and get up to speed, shift to 3rd and 3rd OD and that would have me running at 2.75:1 or so....freeway flyer....
Do you guys {or ladies} think this could work. I can not see why it would not, but that is why I am asking...you folks are way smarter than me.
