Between a 331 flanged 44 and a 373 flanged 44 axle, is the carrier the same? Some carrier interchanges break at certain gear ratios. I have a flanged non TT 44 with 373 gears and I intend to use the TT carrier out of my 331 flanged if they are the same. Thanks in advance for the help.
differential carrier question please......
'59-'64 Chassis Parts Catalog Group 1004, 1004-6 CASE, Diff. Pg. 304.
Come on Rich. are telling me that you live in South Bend and do not have Manauls and Parts Catalogs? Lol!
3.07-3.73 = Same Case
4.09-4.56 = Same CaseStudeRich
Matt, he had to have taken the entire Carrier (Case) AND the Ring and Pinion out of the Housing and swapped it, because a 3.54 Ring Gear does not fit onto a 4.27 Case.StudeRich
Originally posted by AKAchamptrucking View PostBetween a 331 flanged 44 and a 373 flanged 44 axle, is the carrier the same? Some carrier interchanges break at certain gear ratios. I have a flanged non TT 44 with 373 gears and I intend to use the TT carrier out of my 331 flanged if they are the same. Thanks in advance for the help.
Bob
LOL Thanks Rich... I just posted the question since I was busy figuring I could tap the wealth of knowledge here. I bought the rear just to get the rest of the self adjusting BS I was missing and when I got it home and cleaned the tag it turns out to be a flanged 373 rear. It was in a 66 Cruised 4 door. I might O might just put a lock right in it and keep the 331 TT intact in case I break a rear end. I am guessing with that 373 rear and some small slicks I can easily be in the low 12's. That would be even more fun than it is now. I am just tight on coin,dang it.
Originally posted by irish View PostDon't forget the 3.92! 3.92-4.56 = Same Case
The listing in the Showroom Dealers book maybe was not supposed to happen, but that does not mean that one or two were not ordered.StudeRich
