Spring Bushings for 3E 12-21
  • Spring Bushings for 3E 12-21
    Does anyone have the part numbers for front and rear spring bushings.
    I am confused on the part numbers out of the Studebaker International book.
    For a 1958 3/4 ton Trans star AKA Gus.
    Thank you
    He is getting some upgrades.
    Mabel 1949 Champion
    Hawk 1957 Silverhawk
    Gus 1958 Transtar
    The Prez 1955 President State
    Blu 1957 Golden Hawk
    Fresno,Ca
    Anne,
    I would think a town like Fresno would have a few shops capable of bonking the spring bushings you need. They are not Stude specific.
    '33 Rockne 10,
    '51 Commander Starlight,
    '56 Sky Hawk
      I've had good luck at Napa. Like these?
      http://www.napaonline.com/Catalog/Result.aspx?N=43093
      http://www.napaonline.com/Catalog/Ca...850_0318418005
      http://www.napaonline.com/Catalog/Result.aspx?N=27543
      Click on the part and it will give the specs.
      Gordon S
        I have truck leaf spring bushings, if you will give me the dia you need. They are cheap.
        Barry'd in Studes
          You could always raid your foam hair curler set as a temporary fix. Of course...Gus might object to having pink spring bushings.
            If yours are same as mine were, replacing the stock rear spring bushings is not an upgrade. The bolts will always chew through the unlined rubber in short order. I replaced mine with bushings which had a steel sleeve inside and they were still good to go twenty years later. On my first truck I used some Saab suspension bushings, but that's what I had on hand. On the second truck, I took the dimensions to a spring shop and they found some Ford truck bushings with the same OD as the Studebaker spring eye and which had a steel inner sleeve with the same ID as the Studebaker bolt.
            The best fix would be to have a spring shop make up two new main leaves with the larger diameter bushings which all trucks use these days. These would improve the noise isolation, the ride and would last forever.
            jack vines
              Well he just loves his big Pink Cowboy Hat. LOL
              Mabel 1949 Champion
              Gus 1958 Transtar
              Fresno,Ca
                Thank you I'm going to show this thread to David so he can figure out which way he wants to do this. I really Appreciate all of the help. He just tells me to order them but I have to do all the leg work with limited info. So he is measuring them so hopefully we can get something that works good for him.
                Thanks Again
                Mabel 1949 Champion
                Gus 1958 Transtar
                Fresno,Ca
