A dozen years ago, I was asked by a fellow chapter member: what could be done about breaking the 289 in his '56 President loose. This guy was a wisp of a fella and had been trying to break the engine loose with the one and a half inch socket on a breaker bar stuck into a 3 foot cheater bar (big-azz piece o pipe). It had had MMO, tranny fluid and penetrating oil poured into it's bores for a few weeks in advance. Nothing he could do would make it budge, so he asked if I'd try my hand at it - my prodigious bulk being percieved as an ass-set. <G>
That big bolt actually held it's ground no matter which way I tried to force it. The car had been setting in a barn for more than 20 years prior. I was pushing and pulling for all I was worth - maybe 15 minutes or so. Finally - at one point during a clockwise exertion, I felt a little pop. With extreme effort, it yielded to pressure as I reversed the force. With each back and forth, it would go just a tiny bit farther. After repeated pushin' and pullin' - and that thing really resisted at first - I was able to get the engine thru a full revolution. All the plugs were out of course, and I remember getting doused with oil at one point when I got good enough movement to expell some of the accumulated oils in the cylinders.
A few days later, he put the starter back on (he'd been trying to turn the engine by prying on the ring gear!), cleaned the points and then and spun it. Dang thing fired right up. What was amazing was that it didn't smoke a BIT after it burnt off all the penetrants that had been used in the cylinders! Matter of fact, he was driving it around just a few minutes after it started - the original automatic shifting as if had been driven all along.
