Could someone please provide a good clear photo of the c-pillar trim on a 53/54 c/k Studebaker that divides the roof color from the body color please. Could you also give and overall length of the piece please. Thanks, Junior.
photo required.
It's actually a Studebaker script item. Previous threads have even dealt with how the paint line angled up to the drip rail. Maybe someone here has quick access to those previous threads.Brad Johnson,
'56 Sky Hawk in process
The most recent thread on this I recall is this one:
http://forum.studebakerdriversclub.com/showthread.php?49233-1954-Coupe-Paintline&p=530865#post530865This is the place for all non-technical Studebaker topics.
The paint break line goes through the 3 peg holes for the script and then goes at a angle to meet the window trim perpendicularly right at the end of the script.
The red car in Brian's post is a '56 Hawk C body with different paint break than a '53 or '54. There are some '54 C with same or similar paint break and that stainless trim behind the rear window on the deck.
Jeff in ND
Thank you....I was under the assumption that it was an aluminum plate with Studebaker stamped in it. I have no idea why I thought that. Regardless, can someone measure this c-pillar script's length and let me know please? Once again, this forum proves invaluble to my personal Stude pursuits. Thanks. Junior.sigpic
1954 C5 Hamilton car.
I just went out to the garage when I got home and took these pix of the C pillar scripts on my car. These are reproductions I bought from Packard Farms back about 1994. The car has been repainted but I was careful to duplicate the paint line as it was originally. There are 3 pegs to hold these on and I used the original holes after drilling them a bit larger since the reproduction part pegs were a little bigger. The paint line goes right down the center of the row of holes and then angles up the window seam as you can see. The emblem is about 1-1/2" up to it bottom edge from the flat part of the body.
Jeff in ND
Thanks for the help guys...I was all pumped until I got home and re-measured. This script is exactly what I want but it won't fit. I need something like this that is less than 7" long. I will keep looking. Thanks so much for the time and trouble. Junior.sigpic
hey I have no idea where you dug this stuff up...think Smokey could have used this to create his 7/8 Chevelle??.Originally posted by Jeff_H View Post
http://www.google.ca/imgres?imgurl=h...D8zUiALY3u2XDwsigpic
