stiffen seat springs
  • stiffen seat springs
    I am starting to redo the seats and the existing coil springs compress too much resulting in sinking down excessivley. I will add some foam rubber across the top but this wont really help stiffen the springs. Has anyone some ideas on what can be done to stiffen this coindition.
    thanks
    Mike D
    A few days ago, while looking for other things, I ran across a website that offered replacement coils. I am sure that if I could find it by accident, you can on purpose. They are available.
      I have heard that sometimes to strengthen the springs you can connect them to each other, in different directions but in a symmetrical way and then add the additional cushioning. (Never tried this.)
        I was told that the springs need to be tied to one another...they will work with each other to form a more rigid foundation....they won't be able to shift or drop...they will hold together at the same height...if they pitch from side to side, they, again, will move together...extra foam or padding will not take the place of weak springs....
          The guy that done my 48 seats wrapped the coils in burlap and tied them together. They turned out real good.
            Studebaker listed "add on seat springs" as an accessory at one time.
              "Select-O-Seat" was the name of the addition coils.
                OK, it took a little searching but I found the site that had the replacement springs.
                Give it a little time to load and go to page 46. I hope this helps.
                  thanks
                  Mike D
                  A quick, simple, and so far permanent fix is to put a piece of foam inside each coil. I did this on the truck 10 years ago, the seat is still firm and comfy, and look perfect. I also reinforced only one row of coils in the seat back for lumbar support. In mine the location was perfect, your results may vary!
                  Ron Dame
                  '63 Champ
                    You are correct Matthew.
                    I've got some of these, AC 1625, listed for '48 thru '53 Champion and Commander. Still in the box, with instructions. Instructions seem to indicate a 'set' is six coils, but this box only has four.
                    SOLD!$15 plus shipping if anyone wants them. Email me at r1lark@aol.com if you want them, first come first serve. Pics are below:
                    Paul
                    Winston-Salem, NC
                    Visit The Studebaker Skytop Registry website at:
                    Check out my YouTube channel here:
                      email sent
                      Mabel 1949 Champion
                      Hawk 1957 Silverhawk
                      Gus 1958 Transtar
                      The Prez 1955 President State
                      Blu 1957 Golden Hawk
                      Fresno,Ca
                        There are usually a couple layers of pad above the coils. It would be possible to sandwich a layer of thin stiff carpet (indoor/outdoor) under either layer, distributing weight across more coils.
                        Brad Johnson,
                        '56 Sky Hawk in process
