Wondering if somebody can explain how this device works....
Vacu-Matic
The picture shows a thin metal section with directional perforations around the edge, presumably for the air bleed to create a vortex under the carb flow and increase efficiency.
All it does is lean out the mixture somewhat, maybe resulting in a miniscule increase mileage, but more likely an over-lean condition, that will bite you in the butt, down the line.
Late in the 50's, there was another device on the market, labelled as a 'Mini-Supercharger'. This was a 2 barrel insert, with air-bleed driven impellers. The little spinning propelers were supposed to 'supercharge' your engine..
Ever see the magnetic fuel filter that aligned the gasoline molecules and ...... hmmmm64 GT Hawk (K7)
1970 Avanti (R3)
Here's the correct scientific explanation.
You have money.
You buy this thing.
You had money.
Works every time
Jeff (just a vacuum bleed to the intake manifold)[8D]
