I have three(3) '58 Packard hood scoop bezels. The one that was on the car(pitted)and another one(less pitted)both have mounting holes drilled on the outside of them near the front edge on each side. Oval Phillips-head screws held them in place. There was a countersink on the hole, so the screws would sit flush with the ornament. You can see that this was likely done after the part was plated, and they are nearly identical in this respect. The third, (and best, conditionwise) scoop bezel I have has two studs mounted in holes drilled into the underside of it, that correpond to holes in my hood. All three have holes for studs cast behind the blacked-out simulated air intake area of the bezel. Not that it makes a "hole" lot of difference, but still, I wonder if other 58 Packard owners have noticed this? Hopefully, this thread won't end up having to be locked.
are to disagree! [}
