PC-7 epoxy paste available from Ace hardware True Value and other stores. Just do a search on the net to find out where to buy in your area. I have used it more than once with great results. Use lacquer based primer and color coat available from AZ or other sources. Use a clear lacquer top coat. Use whole can of primer, color and clear. Spray multiple coats of each. Depending on how well you can use a rattle can will dictate your wet sanding between primer,, color ,and clear. Follow up with rubbing compound. Call me at 304-723-5253 and I will be able to tell you the exact method for great results,however this is my method only.There are more ways than mine. Paint and epoxy will be less than 25.00. jimmijim
Steeeering wheel with a couple ring wheel question
heres the rest,hit the send button by mistake.
What do you guys use for fixing the cracks and whats the best paint?
thanks!
thanks!
I know we've talked about this before,but Im wondering if anyones found something better.
I have a nice Hawk stTags: None
