Hey gang, here in Portland, Oregon with a '59 Lark 6 HT that won't start. It all began when I decided to adjust my carb. to run better with E-10 fuel, which is all you can get around here. The car had been dying when it was cold so I turned the choke to +1 from -1, which seemed to be too much, within a week the plugs were black from the too rich mix. I replaced the plugs, put the choke back where it was but I made the mistake of fooling with the low idle and the idle screws. This engine has a higher than average amount of compression due to the head being shaved a few times which I understand means setting the idle is a bit tricky. I have started a carb. log documenting every turn of the screw. I have cleaned it pretty well, it's getting spark, it's getting gas, the butterfly valve is totally closed once I step on the gas, plugs are still clean. Last night driving home from work it started fine, it was a little lean I could tell, pulled up to the first stop, took my foot off the brake and put it on the gas; dead within 3 feet of the start and in a busy intersection I might ad. Restart, put it in gear a few agonizing feet, dead. It took me two changes of the light to get through the intersection two or three feet at a time. I pulled over and let her run for a few minutes in park and things were almost all better. When I stopped at the lights from there on the engine seemed to want to die and it ran hotter than normal but she got me home.
I have been screwing with this thing for weeks and I only seem to be making things worse, now she won't even start. If there is anyone in the area that could help me learn what I'm doing wrong it would be greatly appreciated, beers on me. Even a recommendation of a traveling carb. medic would be great. My grandpa is a retired mechanic but there is only so much he can do over the phone. I am so sick of wasting my time making the problem worse. I have gotten good advise from the forum in the past.
I am at my wits end[V]
Thanx in advance, Jsin Cread
