Vacuum control solenoid needed.
  • Vacuum control solenoid needed.
    My '62 Champ pick-up, V-8, auto trans, need the transmission vacuum control solenoid replaced. Where can I locate one, part number 1690850? I have searched vendors and it is not stocked. What AMC part number may interchange?
    Check out this item on ebay right now: http://tinyurl.com/nr5j87
    Dan Peterson
    Montpelier, VT
    1960 Lark V-8 Convertible
    1961 Lark Crusier
    1962 Lark V-8 Regal Convertible
    Dan Peterson
    Montpelier, VT
      Wow, I bet that is scarce! It has a BIN......
      Paul
      Winston-Salem, NC
      Visit The NEW Studebaker Skytop Registry website at: www.studebakerskytop.com
      Paul
      Winston-Salem, NC
        Doug what he very cleverly "forgot" to mention, is it's for a 6 Cyl. It is also available at SASCO.
          What would be the difference between the operation of the 6 cyl versus V8 solenoid units?
          Dan Peterson
          Montpelier, VT
          1961 Lark Crusier
          Dan Peterson
          Montpelier, VT
            Well since all it does is control the throttle pressure and provide an electrical kick-down, it would have to have a different throttle pressure setting (maybe diaphragm spring tension) to match the Trans. shifts to the much lower power of the 6 cyl.
              If I understand it right there are two functions of these units, one is an electrically activated downshift via the kick-down switch on the throttle control which would drop to a lower gear when you "floor it" such as in passing another vehicle. It is likely that this function would not change much between a 6 and 8. The other function is a vacuum activated up/down shift based on engine load/speed which would likely be different between a 6 and 8. Going on the assumption that the weaker 6 would require a downshift a little sooner and an upshift a little later would it be possible that the 6 unit would work adequately for the 8 with the understanding that it was going to act a little different than originally designed? As parts become scarce this option might be better than not driving the vehicle at all.
              Dan Peterson
              Montpelier, VT
              1961 Lark Crusier
              Dan Peterson
              Montpelier, VT
                Thanks for the heads up Rich. I will continue to investigate. We have a transmission guy in the Chapter that should know.
                  For the record, that seller is actually SASCO.
                  Parish, central NY 13131
                    rqa40 is not Dennis. IIRC, that is Bill Stroud in Berrien MI. I have purchased a lot of parts from him, even pre-eBay and pre-internet.
                    Paul
                    Winston-Salem, NC
                    Paul
                    Winston-Salem, NC
