Studebaker truck. $900 or best reasonable offer. Rust in usual locations. Doors/fender/hood are off, but I do have them. Truck is quite complete, however it probably has not run since 1977. I have good Nevada title. Has "new used" tires and battery. Engine will turn over and I think it would run just fine, This is a project truck and would make a fine rod. If you are up to working on automobiles, the mechanicals of this truck are about as simple as it gets. Included is the original Studebaker shop manual. However, it does need body work, unless you are a Rat Rodder, and then it is pretty much ready to go. Parts are very available for these trucks, so anything it needs is pretty easy to come by. It is a C-cab 1/2 ton, the first year for the one piece windshield, but still has the cool small back window. Big six flathead with overdrive, which means the engine bay is big enough for just about anything. Has a few dents, but nothing major. Worst rust is in bottom of doors, included are a set of patch panels and a extra door. Rust thru in bottom of all 4 fenders, about quarter size holes, also pin holes in cab corners. Windshield and rear window glass appears to be ok, side glass is gone, but it is flat and cheap. It is a roller, and I would help you load. It pains me to give this truck up, but it must go. Anyway, if you are serious, contact me and we can arrange to have a look. Note, this is a as is truck, no warranty is given, you get what you see.
Try this link to photobucket for pictures of the truck.
Reply to: sale-cknyu-1108903251@craigslist.org
Alphues
58 packard H.T.
Alphues
58 packard H.T.
