Clover leaf block Value
  • Clover leaf block Value
    Would any of the wise members of this Studebaker fraternity care to guestimate a value of a:
    Factory R2 short block (cloverleaf stamped)
    Full flow
    Never run (still covered in assembly lube)
    NOS crank (long nose)
    NOS cam (1557663)
    NOS Cam gear aluminum
    NOS crank gear
    NOS oil pump
    NOS oil pan
    NOS rods
    Came with R2 pulley and damper on the crank, timing cover has timing indicator plate
    Unsure of the pistons...6 of the 8 appear NOS
    Don't know the year of production but being a full flow would put it somewhere after mid 62 ?
    Looking for a value
    Thanks in advance
    Bill Foy
    1000 Islands, Ontario
    1953 Starlight Coupe
    well, that leaves me out....
      Pictures be nice.. So is this an assemble engine? Oil pan, R2? has the big hole and breather tube? The NOS replacement blocks I have seen, is just the block with the Pistons (pins no rings) in it. There was also a cover where the top center oil filler tube would go with an embossed metal tag with the part number for R2 replacement..
        What about the Pistons, are they Flat Top R1/R2 or Standard 289 Dished ?
        It would be very hard to place a Value on this, without seeing the condition of the Pistons.
