I recently put LEDs into my 6 volt 50 Stude Business Coupe. My rear lights were never very bright. I was going to paint the inside white etc.....but I thought I should check things out first. I found that my voltage at the tail/brake light was 5.9 volts even with the engine running with 7+ volts charging. My Stude is an excellent original, with very nice original wiring....but what can you expect with 70 year old wiring and connections.
I did extensive research with excellent results. By the way, my Champion taillight only had the top socket with a working bulb. I'm guessing the Commander used both the top & bottom sockets. I had to add a bottom socket and I spliced it into the top socket...so now both top & bottom sockets light up.
I found a supplier that has the perfect bulbs in both 12 & 6 volts with both + and - grounding. They have a large collection to choose from. You need to be careful to make sure the bulb will fit the space provided. They provide spec measurements of the bulbs so you can figure the size will fit.
The 6 volt bulbs work with voltage below 6 volts so my low voltage problem was solved. They tell you the voltage range the bulb will work.
The supplier is found at "ledlight.com"
I've done 3 cars....my 50 Stude 6 volt, a 51 Ford Crestliner 6 volt and a 39 Chevy Woodie 12 volt.
The bulbs I used are: 64854, 68574, 62147 & 68465. I think the first 2 are 6 volt and the last 2 are 12 volt....I'm not sure....read the descriptions to make sure you get the right voltage.
These bulbs put out 900/750 lumens. They come with offset bayonets and parallel bayonets so you can get the right ones to fit your sockets. You'll also need to purchase an LED flasher (also from this site).
The result is having lights that are very noticeable even in bright sun light!!!!!
This worked for me and the advantage is the bulbs work with a range of voltages.
