What is the paint code for Turquoise 63 Avanti
Paint code
I doubt that you are going to be able to match an original paint code for the nitrocellulose lacquer as used on an Avanti that would do you much good. There used to be cross referenced formulas to more modern paints, but even the cross referenced paints might be obsolete.
FWIW, Avantis were painted with acrylic lacquer.
I suggest you contact TCP Global. I have purchased paint from them before and they have a close match to most colors. They can provide acrylic enamel, acrylic lacquer, or urethane in either single stage or BC/CC. Otherwise, you can take a sample to your local paint supplier to have them computer match.78 Avanti RQB 2792
64 Avanti R1 R5408
63 Avanti R1 R4551
63 Avanti R1 R2281
62 GT Hawk V15949
56 GH 6032504
56 GH 6032588
55 Speedster 7160047
55 Speedster 7165279
I have it in modern PPG base coat. Ask Matt Burnett how it matches.Bez Auto Alchemy
PPG code in the shopline brand is 12525 You might have them eliminate the J70 medium aluminum from the formula, and add additional fine aluminum (J73) as the original paint was lacquer, and did not have the coarser aluminum.Bez Auto Alchemy
