64 Gran Tursimo Options
  • 64 Gran Tursimo Options
    [?] I have a 64 GT and am doing a bodyoff restoration. The 64 is an automatic car but I really wanted the 4 speed. I recently found a 62 GT parts car with the 4 speed for the swap. The 62 has anouther option I could use some help with. It has a small radiator under the passenger bucket seat. Was this for additional cooling or was it a seat heater? Also was it an option available in the 64 model year?
    Any help is appreciated.
    Mark Plucenik
    Studebaker went from the under seat heater that they used since 1953 in the C/K models to the more conventional engine compartment mounted heater in early '63. Yours would have the later, and no under seat heater was available in '64.
    Bellingham, WA
    [IMG][/IMG]
    Bellingham, WA
      Hi Mark; welcome to SDC and to the SDC Forum!
      Mark your car has the NEW improved Climatizer Heating and Defrosting System that replaced the old under seat heater core in 1963 on the Hawk Models. [^]
      Yours is in the fibreglass box on the right inner fender instead. You have fresh air Defrosting that the old system does not. []
      You still need to have the right fender outside air door open however, to get air flow to make the system work the best. The handle is under the dash on the right. [:0]
        Mark: Dick & Rich helped with the heater issue, so there's no more to be said about that.
        I want to caution you to be sure to dial-indicate the bell housing from the '62 when you put it on the 1964's engine block, per the Shop Manual.
        Also, you will have to remove the engine oil pan and replace the shorter crankshaft-to-flex-plate bolts for the automatic with the longer crankshaft-to-flywheel bolts needed for the 4-speed. If the '62 is a complete parts car, you may be able to get the longer crankshaft bolts from it, but I'd recommend getting new bolts to save trouble and be safe.
        Good luck with the project! BP
          Hi Mark,
          We are putting a GT Hawk Registry together and would like to include your car. Please contact me direct at studee64@cogeco.ca and I will send you the registration information.
          Thanks,
          Barry Leppan
          Burlington, Ont. Canada
          64 Daytona HT 5-spd
          64 GT Hawk R-1/AC/Powershift
          Hamilton Chapter
          Barry Leppan
          Ontario, Canada
          64 Daytona R-1 Convertible & 64 GT Hawk R-1
          GT Hawk Registry & SDC, Hamilton Chapter [IMG]
            barry maybe you can send me the same info as I also have a 64 R-2 full package car, and would be interested in the new group....Bob Peteson....candbstudebakers@sbcglobal.net
            Candbstudebakers
            Castro Valley,
            California
              Bob, is your email Peteson......etc or just candbstudebakers@sbcglobal.net
              tks
              Barry
              Barry Leppan
              64 Daytona HT 5-spd
              Hamilton Chapter
              Barry Leppan
              Ontario, Canada
                Mark,
                Welcome to the forum. Bob makes an excellent point! You need to change the Crank shaft to Flywheel bolts. Dialing in the bellhousing will ensure proper alignment for the transmission to the engine.
                quote:BobPalma Posted - 01/07/2009 : 9:09:28 PM Mark: Dick & Rich helped with the heater issue, so there's no more to be said about that.
                Follow my post of "How to dial in a Bellhousing" You can find it on this fantastic website of Bob Johnstone's
                Here's the links:
                Best of luck with that GT Hawk!
                Allen
                1964 R2 GT Hawk
                1963 Daytona Convertible
                Oakville, Ontario.
                Hamilton Chapter
                See you in Cedar Rapids Summer 2009
                1964 GT Hawk
                PSMCDR 2014
                PSMCDR 2013
                Victoria, Canada
                  Guys ,Thank you for all the info, I have had this car for around 8 years now and and redone the frame and suspension. Getting ready to do the engine and trans swap. The body is still off and I have NOS rear quarters and front fenders, the doors and hood are perfect but I still need to get rocker panels and floor pans as well as the normal trunk deck rust repair.
                  Just getting back to this project after a few years.
                  Thank you , Mark
                  64 GT
                  34 Chevy 5 window
                  37 Packard 120 conv
                  65 & 64 Karman Ghias
                  67 & 73 VW Beetles
                    Mark; the reason some of us guessed that you might be using the original '64 Engine and mating it to the 4 Speed Clutch Housing and Transmission, is that we know that the full-flow is a better engine and the '62 may not be one, if it is an early '62! [:0]
                    Maybe that is not an option for you, as we do not know the condition of the '64 Engine.
                    Also if car value is important to you, the '64 289 Engine has a radically different Serial Numbering system than a '62, and would be easily spotted as incorrect. [:0]
                      The 64 has a good rebuildable engine . running good but using some oil when it was disassembled 10 years ago.I will get the engine # Saturday in better light and reply again. The 62 parts car is shot. The 4 speed and rear are OK ,the engine is stuck , frame rotten and no good body panels. I still have the car but expect to trash it next week. I will get the engine # off it Sat. AM and maybe you could let me know if they are the correct engines and if there is any thing special. IfI am reading you correcty are you saying the 64 engine is the better of the two years?
                      Thanks again . Mark
                        Thanks again . Mark
                        Yes, Mark: If you will post the stamped (not the raised, cast) numbers on the very front of the engine block, driver side, we'll be able to give you everything you want to know about the two engines at your disposal. BP
                          The '64 engine has a full flow oil system with a spin-on filter on the bottom of the engine. The '62 has a partial flow oil system with a filter on the top of the engine.
                          Don't trash that Dana 44 from the '62 either. Check to see if it is twin track (Posi). To check it remove the oil plug and stick your finger in the hole. If your finger stops right away it's a Twin Track.
                          There are lot's of guys looking for them too.
                          1964 R2 GT Hawk
                          Oakville, Ontario.
                          Hamilton Chapter
                          1964 GT Hawk
                          PSMCDR 2014
                          PSMCDR 2013
                          Victoria, Canada
                            Barry, just use candbstudebakers@sbcglobal.net
                            Candbstudebakers
                            Castro Valley,
                            California
                              Hi Rich, I also have a 64 Hawk GT and as a word of encouragment, it is the finest driving Studebaker I have ever had! (and I had quite a few) Best of luck and get her on the road! Mike
                              M.hopinfox/Kennesaw,Ga.
                              63 Champ (connie)
                              64 Commander(commando)
                              64 Hawk (nite rider)
                              65 Daytona (pumpkin)
