Had the tractor going to move some vehicles around, so while I was at it, I picked up a sad-looking Champion six that was a relic of our chapter's parts stash at another location. "Either you take it, or it goes to Blackfoot Metals". So, I took it. There's a V8, too, with a Flightomatic on it.
I got the engine on my outside workbench, and propped it upright, which took some doing, because the oil pan was quite round on the bottom. Water had got in it, and frozen, and stretched it out. It was stuck, of course. T-96 transmission, no OD. Transmission rusty inside, a parts transmission for sure.
Got the head off. Gee, the bores look pretty nice, scarcely any ridge. Got the bellhousing, clutch, and flywheel off. Ring gear rusty, and worn on both sides, so somebody flipped it once. Took the front pulley off, and the timing cover. Pulling the crank timing gear caused the cam gear to break, as neither was about to turn.
Rolled it over; got the pan off. Rusty inside, and oil pump pickup trashed by rust and ice. All the bearing caps came off OK, and crank journals are discolored, but not really badly pitted. Might polish up? Looks like rod journals were cut .010, and undersize bearings fitted. Lifted the crank out. Got 5 of the 6 pistons out without busting anything. #4 is stuck near the bottom. I ran myself out of time today. Will probably try to knock it a little further down the bore, run the hone in it, and then back out the top. Pretty sure the pistons are oversize, too, but by how much, I don't know. Things were really dirty...
Engine serial number is C63886, which should be a '55 185, but it's fitted with 12 volt starter and flywheel. Block casting number is 533870-4, and head casting number is 536180, which is consistent with 1955, too. I have not measured the stroke of the crank, nor did I record its forging number. Pretty sure it's all 185 stuff, though. Definitely a large-journal crank. What I could see of the bearings looks good.
If somebody needs a 185, this might be worth looking at. It might just clean up to be a running engine without rebore or a crank grind.
