so, I decided that since none of my tires are actually the same size, and 1 still has a tube... yep, a tube... I would remove the wheels tonight and get new "used" tires this weekend as well as all my other planned adventures....
well... jacked the car up, put it on stands, and the passenger side came off without a problem... 10-15 minutes worth of work and we got down to brake drums....
Have to admit... I did struggle with the driver side for a good 2 hours... none of the lugs would give... got a hammer... didn't help... finally thought that maybe if I tighten a lug, and then remove it, it might give... That's when I figured it out....
that's when after 2 split knuckles, I found that the drivers side is reverse threaded.... yep... 2 hours, 2 knuckles, apparently 2 brain cells....
um, is this common? or has my vehicle been frankenstiened? I feel like I just went through a Studebaker right of passage.... I feel like I might be a man now... either that or my car is just screwed up!!!!!
are the Studebaker Gods laughing at me?
what the heck? reverse lug nut threads? when was that a good idea?
