Where can I get the rear shackle spring bushings for 1962 Studebaker Hawk? All leads appreciated. email: riokie@gmail.com or PM. Thank you, chet445
Hawk rear leaf spring bushings - Where to buy? Interchange?
Welcome to Stephen Allen's LLC Why choose Stephen Allen’s as your Studebaker parts supplier? You'll receive top notch customer service, competitive prices & quality restoration parts. You'll also speak with knowledgeable staff who own, repair, restore & drive Studebakers themselves, really. We have a large, diverse inventory with a broad selectionHTIH (Hope The Info Helps)
Paul
Winston-Salem, NC
Visit The Studebaker Skytop Registry website at:
Check out my YouTube channel here:
Here are More of the Studebaker Vendors: http://studebakervendors.com
All of them and more, keep these Rear Spring Eye and Frame Bushings in stock.StudeRich
The best and cheapest rear bushings I've used on my 54 Coupe were from an early Jeep. I cut the bushings so I could use one and a half bushings per eye. I buy the urethane bushings to keep it tight.
Now then, I believe the later Hawks have a larger eye diameter on the front of the spring. But I can't remember when it changed.sals54
I made these from "Delrin" and 3/8" plate to replace them in my '62.
I see the stock bushings as a very poor design offering no lateral support to the shackel assembly and very little vibration damping. With very little wear or looseness in the shackel bolts the entire assembly will "Z" allowing the axle to shift under the car. The stock bushing only contacts the shackel with the end of a .060" wall tube that is easilly deformed. The bushings I made use a .090" wall steel tube as well as a 1.5" diameter Delrin thrust bushing that won't allow any lateral movement. They totally stopped the wallowing of the rear end, it tracks like it's on rails now.
stock assembly is on the right.
Originally posted by bensherb View PostI made these from "Delrin" and 3/8" plate to replace them in my '62.
[ATTACH=CONFIG]75747[/ATTACH]
[ATTACH=CONFIG]75750[/ATTACH]stock assembly is on the right.sals54
Originally posted by chet445 View PostBensherb, I did not realize the rear end would move laterally using the standard bushings. I already have purchased standards however what is cost of your setup. Thanks, Chet
The stock bushing only offers 5/32" (0.156") of rubber for vibration damping and it's really hard rubber so there's not much to curb vibration there. My Delrin bushings are harder than rubber but I notice no difference and they work great. Sal's urethane bushings likely offer more vibration damping than either Delrin or stock, but the main thing is to eliminate the possibility of lateral movement in the shackel. As Sal did, a thick washer filling the space between the shackel plates and the spring/frame should do it. Delrin, urethane or even alluminum would better for a washer than steel as it won't squeak. Thicker shackel plates with holes that fit the bolts tightly help a lot too. Another approach would be to weld bars between the two shackel plates making an "H" of them, but there just isn't sufficient room without replacing the shacels with very long ones and raising the rear of the car. (my shackels are a bit longer than stock)
Originally posted by Studebakercenteroforegon View PostNo need to overthink rear spring bushings. The standard replacement bushings will serve you well.
Jack VinesPackardV8
- Likes 1
