I recently purchased the 1966 Commander that was on Craigslist in Sacramento. https://sacramento.craigslist.org/ct...421921674.html
The previous owners bought the car in 1969 and it shows a little over 104,000 miles. It had been sitting for about 20 years before a friend of theirs helped them get it running and put it up for sale. There is no rust on the body but it needs a few small blemishes worked and new paint. There is only surface rust on the frame and some rust flaking under the rubber floor mat that has me a little worried, but I did not see any rust from underneath. The engine runs good (needs a tune-up) and the front end is tight but it is harder to steer than my late model cars; this is probably just a sign that I haven't driven a Studebaker in over 25 years. The only thing wrong with the interior is the wind lace, a 1" crack in the dash near the radio, the kick panels and the panel under the rear window. The seats and door panels appear as new with the stock woven nylon/vinyl seats. I had to fix some wiring problems and address brake issues, but it is now a safe driver. It still needs some work to make it a reliable driver, and then I will turn my attention to some of the cosmetic flaws.
The next problem that needs attention is the transmission; it has a T86 3 speed (no overdrive) that makes a loud knocking/clanking sound in first gear that increases in frequency as the speed increases. Once I shift to second and then third the noise is gone. I have a couple of questions:
1) Does anyone have an idea what might be wrong with the transmission based on this sparse description?
2) Does anyone know of a good transmission shop in the San Francisco Bay Area that could repair the transmission? I have never torn into one, only done R&R.
3) Does anyone have a good 3 speed transmission that would fit a 1965-1966 283 V8 that I could use as a replacement? Preferably within a 100 miles of the Bay Area; or one that the seller is willing to ship.
4) Ideally I would like to put an overdrive transmission in the car, but would need everything that goes with the overdrive: solenoid, governor, kick down switch, pull-cable, drive shaft, OD wire harness etc… Again it would need to be relatively close to the Bay Area as I don’t think shipping all of that would make sense. Again, I would want one that the seller is pretty sure is in working order.
5) The car has a 3:31 non-Twin Traction rear end. How would this gearing work with an overdrive transmission?
Thanks for any help,
