Has Any One installed some, if so where exactly ? would'nt mind pics of installations,as too what type lights were used.
Back up lights for a Champ P2 bed.
Originally posted by 8E45E View PostI wonder if Dodge did when they used that box.
Craig"In the heart of Arkansas."
I would say "GO FOR IT!" Even if you are trying to keep it original for judging purposes. Back-up lights should be considered a SAFETY ITEM as much as a convenience feature. Thus...as in turn signals, and seat belts, backup lights should be zero points off for judging purposes. At least, that's my opinion. Installed above/below the tail lights, or under the bumper, where or what should be wide open to the preferences of the owner.John Clary
Previous owner put backups on my '61 Champ P2 just above rear bumper. Best place looks-wise, but probably a little too low for greatest effectiveness because of the close proximity of the bumper. Switch is on a separate panel along with fog-lite and extra cab lite switches (and one l haven't figured out yet!).Roger Hill
60 Lark Vlll, hardtop, black/red, Power Kit, 3 spd. - "Juliette"
61 Champ Deluxe, 6, black/red, o/d, long box. - "Jeri"
Junior Wagon - "Junior"
"In the end, dear undertaker,
Ride me in a Studebaker"
In case you want to mount them below the tail lamps and make them look factory: The 1954 Buicks had two small backup lights mounted on the panel below the trunk lid, and would fit nicely on any vehicle with a vertical rear body panel. 60 or so years ago, I mounted a pair on my daily driver 54 Aero Willys (was the only one on my block to have one!) and they looked great.Skip Lackie
Sometimes back up lights for 1974-77 Honda Civics come up on eBay and they are perfect for almost any application where an under the bumper placement is desired. Such could be easily adapted to almost any Studebaker need...
Did Dodge have any backup lights on their own '57-'60 Sweptline boxes?
Then I've heard that my old New Process 540 doesn't have a fitting for a reverse light switch.....1963 Champ "Stu Bludebaker"- sometimes driver
1957 Silver Hawk "Josie"- picking up the pieces after an unreliable body man let it rot for 11 years from an almost driver to a basket case
1951 Land Cruiser "Bunnie Ketcher" only 47M miles!
1951 Commander Starlight "Dale"- basket case
1947 Champion "Sally"- basket case
1941 Commander Land Cruiser "Ursula"- basket case
No Stude. EVER, had a IN the Trans. mounted B/U Light switch.
The models that had B/U's: CARS, were on the Column or Floor Shifting Linkage.
No Vehicles I know of, of our vintages had switches IN the Trans.
If you can't Rig it up on the shifter, you will just have to use a Manual Toggle Switch and remember to use it!Last edited by StudeRich; 10-28-2017, 12:02 PM.StudeRich
How how would you put an external backup switch on a '63 NP540?1963 Champ "Stu Bludebaker"- sometimes driver
You would need a switch on the end of the Top shift Rail at the Reverse gear location, you may have to JB Weld it on there unless you want to risk drilling into the Cast Aluminum Top Cover Plate.
That would be why people usually put a Toggle Switch under the Dash.
This one has Fog and Back-UP light Switches below the "T" handle which MAY be for a Double Overdrive, as it already has a NP540 OD.
Yes that's a '63 Transtar 8E13-131 Dually with a 9 ft. stretched Champ P2 Box with P1 Fenders! Not mine, (I Wish it were!)Last edited by StudeRich; 10-28-2017, 01:03 PM.StudeRich
