Help, trying to find front "STUDEBAKER" hood emblem for my 1955 Stude E7 PU. I have the original but it has screw holes all over it and pitted really bad. I've checked all the Studebaker suppliers with no luck. Found one for '49-'53 but its like half the size. '55 went all the away across. Thanks for any help.
Randy
Randy
) and threaded the studs. Although tapered, I managed to get enough threads to use a very thin washer and nuts. It helped a bit, but I still felt that it was fragile, and insufficient. It stayed on my mind, and I even lost some sleep mulling over how I could fix it without causing more damage to the fragile pot metal. If you examine the back side where the studs are cast, you will notice a "Boss" (Thicker Portion) protruding in the casting.
