I keep getting the warning i am running out of storage, so I try to delete some and it seems to not help at all. Can someone enlighten me on how to get rid of stuff please?
This channel is for questions about how to use the Forum.
Please do not post automotive questions here.
- Use the Tech Talk channel for Studebaker tech questions.
- Use the General channel for other Studebaker-related questions.
- Before asking here, try using the Forum's built-in Help functions!
delete empty mail?
I assume you are talking about the PM mail. In addition to the above, don't forget to go to your 'trash' folder and delete the messages there also - because they count towards the max limit too.Paul
Winston-Salem, NC
You can send your received mail to trash; you can send your sent mail to trash; then they both are stored in trash, until you open the trash file and empty it as well.
The part I find a bit unusual is, if you have communicated with someone, and they haven't deleted those communications on their end, those communications still remain as a restriction to your own total.
Before the tirade ensues, this is not a program created by our administrator, moderator or even web master. This is inherent in the vBulletin software that supports the forum.Brad Johnson,
'56 Sky Hawk in process
That is kindof screwey. Perhaps if requested they would change it...?Originally posted by rockne10 View PostYou can send your received mail to trash; you can send your sent mail to trash; then they both are stored in trash, until you open the trash file and empty it as well.
Before the tirade ensues, this is not a program created by our administrator, moderator or even web master. This is inherent in the vBulletin software that supports the forum.Diesel loving, autocrossing, Coupe express loving, Grandpa Architect.
