The hood hinge links on my '46 Bus Coupe have both been tweaked a bit. They look like they have been compressed down a bit (bowed). I don't have replacements or a good hinge to look at as a "go by" to straighten the links on my hinges. If anyone can help with ANY of the following, it would be much appreciated:
1. A good front view photo(s) of what a good, straight hinge links look like, so I can straighten mine to match.
2. Any end to end, or rivet hole centerline dimensions for the links.
3. With the hood resting on the prop, what is the distance between the cowl and back edge of the hood, about mid way on either side of the hood centerline.
4. The front cross member on my car has been modified, so now the top of the radiator core support no longer rests at the same height relative to the frame. I am concerned about getting the correct slope on my hood. Can anyone tell me the dimension from flat of core support top to the top of the frame rails? Or, how much slope there is from the back of the hood to the front? I can "eyeball" the fit, but would like some idea of where it should be before it is all buckled together again.
Thanks!
Thanks!
