Hurst Shifter Install (Ford Pick-UP)
Transmission / Overdrive: Hurst Shifter Install (Ford Pick-UP)
Looks like it fit around the O.D. Solenoid Ok, that is usually the hard part. Which one of the many Hurst or Mr. Gasket shifter Models is this one?StudeRich
Originally posted by StudeRich View PostLooks like it fit around the O.D. Solenoid Ok, that is usually the hard part. Which one of the many Hurst or Mr. Gasket shifter Models is this one?
jack vinesPackardV8
Originally posted by PackardV8 View PostOn a truck, where the shifter can mount high and forward, as he said, it's cake. On cars, where most want the shifter down and back, is where the confluence with the OD gets problematic.
jack vinesStudeRich
Originally posted by StudeRich View PostWell it's a Ford Truck shifter going in his '56 Sky Hawk Jack, so I wonder if fitting it to his Floor and Seat will be a problem in that position?
I think the shifter mechanism probably will be fairly high.....Might need some type of console around it.
