hi,
have '57 Golden Hawk, freshly bored .030 over, and new hypereutectic pistons and Grant cast iron rings.
Noted that the piston instructions dictate increasing the ring gap on the top compression ring by 40% over "factory spec", due to tendency for these pistons to absorb more heat in that top ring.
OK, Stude spec is 0.008 - 0.016" for both rings; sound reasonable to simply take the mid-point (0.012") and add 40%, and shoot for filing the #1 rings down to 0.017" gap?
Fresh out of the box they were at about .012"... (2nd compression ring is already around 0.016, or at least the only one I've measured so far. Would have been a lot less grinding to open THEM up a bit ;-)
thanks!
Barry
thanks!
Barry
