I am removing the entire front end of my 1961 Lark to rebuild it. The only problem I have is, of course, the show stopper. I can see the two main bolts that hold the inner control arm (upper) to the crossover frame BUT I cannot see the nuts to even get a wrench on them.
The manual says to be careful to not drop the nuts into the inside of the frame but I cannot even see them. How do you get to them to put a wrench on the nuts? It is easy to see the bolts (one from the inside of the engine compartment and the other from under the wheel well), not problem there.
I have the car up on many safe jack stands and the wheel off, the backing plate out of the way and have followed the manual to the "T". It has been direct and easy until now. I have laid under the car and looked directly up to try and find the nuts but cannot see them.
In following the manual, the last thing you do to drop the front end spring is the removal of those two bolts, then the entire assembly sets down on the ground just like the pictures in the book. I only write this to let you know I am following the exact procedure in the manual and in that same order. So far so good,,,,until now.
Any help is appreciated. Thanks,
Gregor
Gregor
