The car is a 62 Hawk. Automatic, all stock except for Mallory distributor. About two weeks ago a sudden engine knock appeared. With the stethoscope I can hear it in the oil pan. Other symptoms:
--no drop in oil pressure
--noise is worse at idle esp when you rev her a little; it goes away at speed and seems to run fine
--less of a fairly loud clunk clunk as engine warms; also less frequent
--the noise indicates that something is loose
My various shade tree mechanic thoughts:
--bad crankshaft bearing?
--bad oil pump?
--bad timing gear?
--broken flex plate?
When I have time in the next week or so I am going to drop the oil pan and take a peek. I have asked a local mechanic to take a look as well, since I have had no real experience with a problem like this (and may not know what I am looking at unless it is very obvious).
Have any of you had similar problems? Any thoughts on what may be the cause of this? As always thanks so much for your time!
--bad oil pump?
--bad timing gear?
