Attention any Chevybaker driver with a manual (V8) shift car: The shop manual for the '65 Cruiser I am working on shows a return spring mounted in a hole in the upper bar of the Z-bar, about halfway, with the other end attached to the body underside. However, the parts book lists only ONE pedal return spring (#284505) and shows it mounted INSIDE the car, with one end at the forward end of the bellcrank the the other end on the instrument panel. This spring is not as beefy as the Studebaker clutch return spring; and in fact when I mounted a #284505 spring inside the car in this position -- voila -- it does not work! I feel I have stumbled into a never-before-broadcast episode of The Twilight Zone, with me cast as the earnest but hapless Studebaker restorer seeking in vain to have his clutch pedal pop back up. Rod Serling is laughing in his grave whilst holding the true spring in his bony hand.
1965 Chevybaker Clutch Linkage Question
The heavier spring should be inside the car. It should be the same as any 61 and up Lark type clutch return spring. The lighter weight spring is an anti rattle spring that holds theChevy clutch fork to the pushrod .Bez Auto Alchemy
Originally posted by bezhawk View PostThe heavier spring should be inside the car. It should be the same as any 61 and up Lark type clutch return spring. The lighter weight spring is an anti rattle spring that holds theChevy clutch fork to the pushrod .
I've had a couple '65 manuals over the years, but none now. Wish I did so I could see that illustration. The 1965-66 manual does not show a spring at the pedal. Additionally, the part number for a '65-'66 pedal is different from a '61-'64 pedal. Try it with the #284505 on the linkage and nothing on the pedal.Restorations by Skip Towne
Originally posted by Dwain G. View PostI've had a couple '65 manuals over the years, but none now. Wish I did so I could see that illustration. The 1965-66 manual does not show a spring at the pedal. Additionally, the part number for a '65-'66 pedal is different from a '61-'64 pedal. Try it with the #284505 on the linkage and nothing on the pedal.
I do not know if this has anything to do with the clutch linkage and springs confusion you are talking about, but is there ANY chance the 3rd. unknown spring could be the short little Coil spring on the pedal cross shaft between the pedals?
That one is the Brake Pedal return spring.
I never depend on the Shop Manual Photos for Parts Configuration, on the Pedal System, some of them are of the very similar FORD System from the same supplier that Stude. used.
Those are obviously before they had it fine tuned and may be wrong, notice the Pedal Pad with the Ford Crest outline on it!
The Chassis Parts Catalog Illustrations may solve your problem.StudeRich
Originally posted by StudeRich View PostI do not know if this has anything to do with the clutch linkage and springs confusion you are talking about, but is there ANY chance the 3rd. unknown spring could be the short little Coil spring on the pedal cross shaft between the pedals?
