Hi everyone, figured I would tackle adjusting my valves since I figured it hadnt been done in a very long time. Car is a '59 Lark 259 with a 3 spd auto. Followed Studebloggers guide and the car fired up fine after I was done.
**Key point. I rotated the engine CCW from the front several times.** Did I harm it?**
Sounded good and I backed it out of the driveway, went down the street and gave it some extra throttle and it died on me.
Would still crank but wouldnt start. I thought i may have somehow flooded the poor car so I let it dry out and tried to crank numerous times. Enough to kill the battery.
Took a stab at it yeaterday and determined i wasnt getting a spark.
Ignition coil packed it in, replaced that after determining it was bad due to no resistance on my ohm meter. First guess was a bad starter solenoid. So both of these things are new now.
Previous owner had the polarity mixed up on the coil and the negative was not hooked up to the distributor.
I connected this before my initial test drive.
Charged the battery today and the starter would not engage. I can tap the line going down to the starter with my jumper cables and I can hear it try to turn over the car.
Im a little lost now to be honest.
Any help is greatly appreciated. Thanks!
