anyone running a 289 for the street and strip ??? if so what tranny are you using ?? what gears ??? im just curious because im thinking about future builds for my 49 2r5
289 v8 setup for street and strip ???
The 54 Conestoga I'm currently working on (actually two of'em)...
One is a daily driver that will see action at the local 1/8th mile track. The other will be much more race oriented and see duty at both the 1/8th mile and 1/4 mile track (a bit further away).
Both fully street drivers, both have T200-4R trans. The driver has 3.73 rear gears and the hot rod has...well it's a Quick Change axle, so it'll be what I feel I need at that moment..!
The hot rod's trans. is fitted with a trans. brake, the daily driver does not.
The hot rods trans. was built by Scott McClay.
The daily driver's trans. was built by Art Carr.
The Official Art Carr 2004R Transmission - California Performance Transmission stocks high performance 200-4R and 700R4 Automatic Transmissions, Torque Converters, Shifters and Racing Parts
Hope that helps a little.
I have been running an R-2 supercharged 289 with a 0.040 overbore (295) for several years. It is a street/strip car and has the 200 4-R OD GM automatic with a 4.09 rear axle ratio Dana 44. Gets 15+ mpg on the highway and runs high 13's in the 1/4 mile and high 8's in the 1/8th mile.Frank van Doorn
Omaha, Ne.
1962 GT Hawk 289 4 speed
Originally posted by austins49 View Postanyone running a 289 for the street and strip ??? if so what tranny are you using ?? what gears ??? im just curious because im thinking about future builds for my 49 2r5
Trannies I've run or know the car/truck which did. T86, T85, T89, T98, T10, Ford top loader, Mopar A833, T5, T56, TKO for a few standards.
Automatics: B-W Flightomatic/Powershift/Ford FMX and AMC versions, GM TH700R4, 2004R, 350, 400, Mopar 727OD.
Gears: everything from 2.56 to 6.33. (Alan was hell off the line!)
When you define your goals and budget, you'll get much more specific advice.
jack vinesPackardV8
Mickey Pearce out of Lakeland Florida is a person that you might contact.
He has a C cab that does run 14's , and is driven . I have only met him once , so
I am only passing on what I know. He has run at the Orphans Drag races , and can
be seen in some of the vids that Richard Poe has posted .Bill H
Daytona Beach
SDC member since 1970
Owner of The Skeeter Hawk .
Originally posted by austins49 View Postwould like ets around 14 seconds and mpgs 17 or better lol as for cost not sure yet
jack vinesPackardV8
