I removed the 2 rear threaded plugs. Only a tablespoon each side of brownish gritty sand with some coat hanger scraping. Can I block the bottom hose, remove the thermstat, fill the block with water and some flushing product. Let soak, then remove the plugs and use garden hose to blast from the thermostat housing. In my mind this sould get me close to a clean block yes/no??
I have read that to be the most thurough is to remove the freeze plugs but: 1) that looks to be a BIG effort and 2) The amout of gritty brown sand was, in my opinion very minimal. Or is that alot?? The car has the oil bath filter which I have read is superior to the paper filters. I hope this supports that my amount of grit is minimal. I hope to flush from the top front to the back rear of the block as described.
Thanks,
Jim
Thanks,
Jim
