I'm planning on installing my new 4 barrel carb sometime in the next week or so. This particular carb has an electric choke on it. What's the best place to run the power from?
Best place to connect electric choke?
If you don't have Overdrive, then use the unused lead for the overdrive solenoid power. It should be the red wire clipped, unterminated, to the wire bundle that runs across the cowl from the driver's bundle pass-through toward the washer motor and distributor. It's hot when the IGN switch is ON, so it's perfect for this use!
