The subject- 1960 Lark V-8 3 speed overdrive
The Problem- Irregular knocking noise above idle speed
When I first looked at my friends car in his driveway the noise seemed to be from the rear of the engine/ bell housing area. Today we had the car towed to my place where I removed the transmission to make sure the transmission wasnt the cause of the knocking. When I place by stethiscope on the bellhousing the noise sounds loud but placed on the side of the engine block I hear almost nothing. At that area the engine sounds like a smooth running sewing machine but I have never heard of a clutch assy making an irregular knock so I am open for suggestions on what you all here think may be the cause.
My next step is to drop the exhaust from the manifolds, remove the bell housing & clutch assy, then reinstall the bell housing & start the engine again, that is if nothing obvious is seen in the clutch. What would you do?
