I've just purchased Avanti 63R1880. It has a surge when cruising at any steady speed. The carb is an Edelbrock 1406. P.O. said the fuel system has an electric pump near the tank, and runs through the mechanical pump also. The line running from the mechanical pump to the carb has a tee in it, the other branch running a return to the tank. Is this as strange as it seems to me? I was told the R-1 has had the compression lowered to run on pump premium. Points and vacuum advance can have been replaced.
Is this enough info to help figure out my problem?
Thanks for any ideas, Kelly
