1955 Champion.
I am getting ready to install my Offy intake dual carb set up. I have to relocate the oil filter. As I understand the 186 has a full pressure system. I looked in my shop manual and it says nothing about the oil filter, I can only presume that from the factory these did not come with a filter.
As I looked further there is one line in the side of the block and the other is located at the bottom of the oil filler tube. Doesn't look very efficient. The oil must enter from the block and then drain back into the pan.
How much if any oil is actually being filtered and if the line was tapped into the block is another component being compromised from lack of oil? Is it really worth the time and effort, if indeed this is aftermarket, to relocate the filter or would I be safe in just removing it completely if it was not factory equipped with a filter?
Please enlighten me.
Thanks in advance
Thanks in advance
